Thread: Refrigerant Pipework Dripping
20-07-2014, 08:26 PM #1
Hi All,
I had AC installed around a month ago and the temps coming out are perfect, the problem that I have noticed is that the pipe work looks to have quite a bit of condensation building up which is dripping and corroding the other pipe/spring around it.
Please find attached pics to show what I'm talking about.
Is this something I should get looked at or is there something I should be able to do myself?
Jake
20-07-2014, 08:34 PM #2
Re: Refrigerant Pipework Dripping
Call back the installer to properly vapour seal the pipework.
20-07-2014, 10:08 PM #3
that will be a bitch to seal properly- basically ping the unit off its wall plate and try and layer up with armaflex tape to a minimum thickness of 9mm, easier to pump it down,remove off the wall completely and reseal then refit pressure test,vac and release the gas back into the system
