    Jul 2014
    United Kingdom
    1
    Refrigerant Pipework Dripping
    Hi All,
    I had AC installed around a month ago and the temps coming out are perfect, the problem that I have noticed is that the pipe work looks to have quite a bit of condensation building up which is dripping and corroding the other pipe/spring around it.
    Please find attached pics to show what I'm talking about.
    Is this something I should get looked at or is there something I should be able to do myself?
    Jake
    11,025
    Re: Refrigerant Pipework Dripping
    Call back the installer to properly vapour seal the pipework.
    manchester
    5,639
    that will be a bitch to seal properly- basically ping the unit off its wall plate and try and layer up with armaflex tape to a minimum thickness of 9mm, easier to pump it down,remove off the wall completely and reseal then refit pressure test,vac and release the gas back into the system
