    Oct 2008
    bingley
    8
    Lightbulb Simple temperature dial out / humidity monitors
    Good afternoon all
    I am just enquiring if this is a subject where a simple cost effective option would be highly welcomed
    Would there be a call for a temp monitoring system that is proven to work using a simple pay as you go SIM / GSM enabled that comes with power supply and probe to connect to cold rooms it suites mortuary's etc.?
    Once power fails it will email text or call , if there is humidity or temp change once set up it will contact you.
    There are logs recorded in the memory
    There are 2 additional input options for Door gas smoke and flood monitoring
    This can be tailor made and more rooms can be added, there is options for IT suites to use internet connection instead of the SIM which would be even cheaper .
    I am currently trying to set up this as a specialised sales area from our company but any feedback would really be appreciated if this technology for approx. £650 would be welcomed ?
    This is a very neatly packaged unit no bigger than the average PDA.
    Any kind of feedback I would highly appreciate and thanks for your time in reading this email
    All the best Lee
    11,025
    Re: Simple temperature dial out / humidity monitors
    Thought these things were already on the market.
    Oct 2008
    bingley
    8
    Good morning Brian - They are on the market but no one seems to be really marketing for our industry I am trying to source something a little more cost effective for the small to mid size outlets -
    looking at the very basic alarm system for example IT suites using Ethernet as a power supply one probe ( facility for a second probe ) monitoring using email alert notification for approx £250 alternative option to the above.
    Instead of heading to the thermalog routes which is expensive and unable to justify the cost for smaller markets .
    11,025
    I had a customer who used a gsm autodialer type unit connected to a simple thermostat, cost about £80 all up.
Tags for this Thread
