Thread: Acid Test
    Sep 2010
    Hertfordshire
    Acid Test
    Hi Guys,
    Any Thoughts appreciated, just went to carry out an Acid Test on a York Chiller, took the sample from the oil fill valve at the bottom of the compressor (scroll) and got a blast of refrigerant/oil, into the test bottle which turned yellow indicating high Acid levels, question is is this test still reliable taken from refrigerant and not pure oil?
    Thanks for any help.
    Oct 2012
    Russia
    42
    392
    Re: Acid Test
    The test reacts to acid, in a certain quantity.
    Where this acid is doesn't matter.
    Oct 2007
    manchester
    5,639
    45
    Re: Acid Test
    usually yorks leak on the sumps, just collect it off the bolt heads, good job the f gas police dont troll on here
    Nov 2008
    United Kingdom
    33
    Re: Acid Test
    yes still reliable. next time use charging line with ball valve on end
