Results 1 to 9 of 9
    Oct 2008
    Australia
    210
    Daikin FHYC140KVE8 - RY140LUY1
    Hi guys
    i have an E4 error code coming up on this unit.
    I have checked the LP switch on the outdoor unit and bridged it out but the error still occurs. The unit actually never runs as soon as the unit it turned on the error code appears straight away.
    I have checked the outdoor wiring diagram and there is a note on the LP sensor saying the following.
    I have checked the HAP light and it does flash when I take out the no 2 terminal wire.
    Has as anyone come across this before? It has really stumped me.
    Oct 2001
    Nottingham UK
    5,668
    Re: Daikin FHYC140KVE8 - RY140LUY1
    E4 is a comms error between Indoor and outdoor pcb's.
    You have a K series indoor unit and an L series outdoor unit.
    These are not compatible
    Oct 2008
    Australia
    210
    The plot thickens then! I'm probably looking at the wrong condenser!
    Oct 2001
    Nottingham UK
    5,668
    It must be Dementia onset...doh!
    E4 is Low Pressure Switch...U4 is Comms error
    In my defence, I've had a long few days and not much sleep....honest :-)
    Oct 2007
    manchester
    5,639
    45
    had it on a panasonic urban- all runs ok, alarms when not there, ended up replacing the comp contactor, all sorted
    Oct 2007
    manchester
    5,639
    45
    green hap led should light flash as soon as powered up to show comms
    Split Croatia
    57
    6,151
    36
    Is there any procedure for reseting alarms? It may be necessary to reset alarm after it's occurrence, and after it's cause has been eliminated.
    Oct 2008
    Australia
    210
    All good.
    I had the wrong condenser. The coil has a leak on it and it has no gas. Hence the fault code.
    11,025
    OK, thanks for the update.
