    Feb 2006
    Romania
    43
    Need help with SO2 fumigation
    I have a customer that wants to build some grape storages, which needs fumigation. He also intend to use these storages for storing apples in CA and ULO.
    The problem is that SO2 is not compatible with CA machines and I need a gas washer which will remove the residual SO2 from the air.
    Can you help me with a supplier for a complete system (dosing + washing)?
    Thanks in advance.
    Sep 2009
    Iran
    483
    12
    Re: Need help with SO2 fumigation
    as you know SO2 with water comes to H2SO3 and it is acid .
    So best way to Remove SO2 is a ventilation system
