Results 1 to 11 of 11
Thread: R718 as refrigerant
06-04-2006, 07:44 AM #1
R718 as refrigerant
Hi sirs
I randomly found an article for R718 water chiller. It's an interesting topic. R718 is H2o. Use water to produce chilled water. Very good. Who know this machine? Is it available for practical use? welcome input
regards
LC
06-04-2006, 07:55 AM #2
Re: R718 as refrigerant
dear sir
would you provide us with more detales
please send internet site of the company who produce this kind of chiller
regards
afeef
06-04-2006, 09:20 AM #3
Hi Lc_shi
have a look here http://www.refrigeration-engineer.co...ead.php?t=2619Last edited by frank; 06-04-2006 at 09:23 AM.
06-04-2006, 09:54 AM #4
You are thinking of a Lithium Bromide / Water Absorption chiller. They've been around for most of the last century, and are still made. They tend to be very large capacity, and can capitalise on large quantities of waste heat.
By today's criteria they have a poor efficiency profile, because of thier high reliance on direct-fired carbon fuels, but still installed. Usually they are around 1 - 1. 5mW (3-4000TR).
I worked on a few in the 70s. The smallest one I ever commissioned was a Japanese Carrier 16JB that was considered a table-top model at 100 TR, (about 350 kW).
LiBro is the absorbent and water is the refrigerant. The system is kept at a vacuum to promote evaporation temperatures in the order of 5 Celsius.
The other variant of the absorption process is a slightly different technique; it uses water and ammonia. In this case the ammonia is the refrigerant and water is the absorbent.
________
vapir oxygenLast edited by Argus; 07-02-2011 at 10:01 AM.
06-04-2006, 11:30 AM #5
Not quite. R718 can be used in a phase change chiller as the refrigerant, bu evaporating and compressing water vapour exacty as any other refrigerant.
Applications are in the range of high evaporation temperature (+20/35°C).
Considerations must be applied for the high expansion ratio after evaporation and low exponent, that would lead to use turbine compressors (high flow, low compression ratio).
Liquid separation is also an issue.
06-04-2006, 11:57 AM #6
http://www.refrigeration-engineer.co...ead.php?t=4124
Not sure about what you saw, LC but in principle water would be great, it's a lot like ammonia i.e. high latent heat, large amount of vapour for the liquid volume.It's a lovely day to pump some gas
03-05-2006, 09:06 PM #7
There are developments of compression chillers using water as refrigerant. Several machines have been in the field test in the recent years. (Megawatt class, I guess). However, the compressor is very special and expensive. Therefore, economics is an issue.
07-05-2006, 12:25 PM #8
Just went back from technical shool.R178 as refrigerant is
a very interesting problem. Here in Denmark LEGO has buildt
a system with water vapour compressor, they use this to
cool down diff. machinery.
Here in Denmark ther has been started a project to develop
water vapour compressors.
By the way a have a PDF file 1.8 Mb. 260 pages concerning
water vapour compressors, so if anyone is interested just
mail to me.
Best regards
Carlo Hansen
07-05-2006, 12:50 PM #9
Hi again
Just forget to set in this link.
http://st-div.web.cern.ch/st-div/wor...ogy/JacekK.pdf
Best regards
Carlo Hansen
07-05-2006, 04:24 PM #10
[ Will be geatful,if you can mail me the PDF file 1.8 Mb. 260 pages concerning water vapour compressors, I am interested.
Myemail :dhaliwals@gmail.com:
Best regards
Dhaliwal
08-05-2006, 01:43 AM #11
I think you can download it by the link
rgds
LCI hear...I forget;I see...I remember;I do...I understand
R600 Refrigerant.
By tonydeith in forum RefrigerantsReplies: 14Last Post: 21-04-2011, 08:52 AM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 01:39 PM -
Best way to sense level of liquid refrigerant in receiver?
By star882 in forum FundamentalsReplies: 2Last Post: 16-11-2005, 06:34 PM -
Liquid refrigerant and bubles in sightglass
By aygul in forum Trouble ShootingReplies: 2Last Post: 30-08-2003, 09:07 PM -
Refrigerant Reclamation
By herefishy in forum CommercialReplies: 6Last Post: 23-07-2003, 08:19 AM
