Thread: help identifying a cooler ?? Plz
26-06-2014, 10:28 PM #1
HI all i wounder if anyone can tell me what is the name of this chiller
I know it made by Costan but unsure what model
The reason i'm asking is the unit now has a fault
its was running perfect so i cleaned the grill at the front & when into the back of the shop to get something to wipe the grill over (a damp cloth)
while i was in the back....my bright spark of a brother decided to play with the controls (bottom right of the photo)
Now when the cooler runs its ok for 30 min's the an alarm goes off & flashes HI in the display
switch the cooler offfor a ,im/ then back on same again ok for 30 min's then the alarm again
I have phoned a few people to come & have a look at it but they all ask the same question what model ??
This i'm stuck with......search the internet for 2 days but still nothing
Could you help Plz Thx phil
27-06-2014, 12:23 AM #2
Re: help identifying a cooler ?? Plz
Fit a new controller elliwell id chill or id cool dependent on temp range if the one fitted has one temp probe it's a cool if two chill not worth the time messing then don't take your bro with you again!!!
27-06-2014, 12:27 AM #3
What you have there is an. Lae controller if you remove it the model number should be on it,he has affected the temperature alarms
27-06-2014, 09:35 AM #4
Hi Thank you for the reply
is there a manual that i can download
so i can reset the settings myself ??
Thx phil
27-06-2014, 09:53 AM #5
Google lae,but you will Need the model number
27-06-2014, 11:00 PM #6
