Results 1 to 2 of 2
26-06-2014, 10:16 AM #1
Hydronic Cassete fan coil unit - power consumption
Hi! I would be grateful if you could help me if you have some time!
I write something about electricity consumption in my office. In the office there are installed hydronic cassette fan coil units. I'm interested in how to calculate their electric consumption within the office. The type is Carrier 42GWC004.
Does it depend on whether it is heated or cooled and should i use in calculations that COP and EER numbers or not?
20-07-2014, 08:39 AM #2
Re: Hydronic Cassete fan coil unit - power consumption
http://www.carrier.com.sg/pdf/13/42G...0catalogue.pdf
http://www.bgtherm.com/products/heat...tions_42GW.pdf
stick an power meter on it for an hour to get ur leccy consumption- as it only powering a fan,pcb, lift pump and your actuators
