Results 1 to 2 of 2
24-06-2014, 11:04 PM #1
Torque settings & tappet clearance TK Ts 300
Hi Everyone .... wonder would anyone know the head torques & tappet clearances and sequence if poss for the T/K Ts 300 ..... (next weeks job) as it seems to be leaking oil from the back of the head .... apparently a common problem, so I am told.....
any help gratefully received !
Brian
26-06-2014, 03:42 AM #2
Re: Torque settings & tappet clearance TK Ts 300
Common problem, make sure you've got water pump gasket, water pump o-ring, valve cover gasket and exhaust gasket as well.
370 or 3.74 engine?
Valve clearance is the same .006"-.010"
The flywheel is marked for TDC of 1,2 and 3 cylinders. #1 cylinder is the flywheel end.
head bolt torque is different.
3.74 - 27.5-30.4' lbs
370 - 39.8-42.7' lbs
Torque it down in increments starting in the middle and criss-crossing
_____7_________1________10
13_______3__________6_______12
11_______5__________4_______14
_____9_________2_________8Last edited by IRMechanik; 26-06-2014 at 03:45 AM.
