    mausmi's Avatar
    mausmi Guest
    Cool R744 as refrigerant and transcritical process
    Good morning!
    I have any questions about the refrigerant R744 in heat pump solutions for custom warm water!
    Have someone experiences wiht that kind of heat pump system?
    With best regards!!!
    path20040's Avatar
    path20040 Guest
    Re: R744 as refrigerant and transcritical process
    Hi , What is yor question ?
    Nov 2005
    Denmark
    8
    Hi there
    I believe Sanyo has made a heatpump using r744 as refrigerant in a transcritical process. I believe you can find information on it at www.ahlsell.dk. Well I just checked it out. You can't find any technical information on the heatpump. But should you want some information you're welcome to post me privately. I will send you some files about it. Or simply contact your local Sanyo dealer.
