05-04-2006, 09:23 AM #1
R744 as refrigerant and transcritical process
Good morning!
I have any questions about the refrigerant R744 in heat pump solutions for custom warm water!
Have someone experiences wiht that kind of heat pump system?
With best regards!!!
20-05-2006, 08:31 PM #2
Re: R744 as refrigerant and transcritical process
Hi , What is yor question ?
21-05-2006, 06:24 PM #3
Hi there
I believe Sanyo has made a heatpump using r744 as refrigerant in a transcritical process. I believe you can find information on it at www.ahlsell.dk. Well I just checked it out. You can't find any technical information on the heatpump. But should you want some information you're welcome to post me privately. I will send you some files about it. Or simply contact your local Sanyo dealer.
