Thread: r407c
    Jun 2014
    pakistan
    43
    1
    r407c
    can i charge r407c in previous r22 ac unit
    Feb 2001
    Doncaster, England
    199
    Re: r407c
    Hi ishtiaq ali,
    the oil may be a problem - as it was using R22, it probably has mineral oil in it.
    R407C will not work with the mineral oil - it has to have synthetic oil (POE).
    Check what oil is in the unit.
    Tony
    Aug 2001
    Gold Coast, Australia
    600
    28
    Re: r407c
    If it's mineral oil, you'll need to do a number of oil changes until the mineral oil content is acceptable (acceptable depends on the oil manufacturer).
    You'll lose about 5% capacity with the R407c.
    Yes, it's do-able, it was a common retrofit when I lIved in the UK.
    May 2012
    59
    1,528
    36
    Re: r407c
    It is do-able but also check any seals inside the system.
    If there are any valves or fittings that have a seal on it,
    be aware that the seal might not stand up to the new
    refrigerant and oil mixture.
    Rob
