Results 1 to 16 of 16
05-04-2006, 02:19 AM #1
Re: Can I leave a system in a vacuum overnite?
Ok, I can see I need to clarify and redirect the question as;
If I have the system hooked up overnite with a micron gauge connnected but isolated from the pump, which is off, it is acceptable if the micron rise is within 500 microns.
Daikin fault codes
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 09:47 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
