    Jun 2014
    55
    1
    display chiller not getting cold enough
    Hi, New here and couldn't find any ideas on this
    I have an igloo chiller display cabinet
    been working fine, but suddenly doesn't get cold enough
    The fan is working on the condenser radiator and it is clean and not blocked.
    Pipes into it hot, and out are cold
    pump appears to be working as hot and slight vibration felt
    but top condenser radiator part in chilled part, get frosted one end, but not cool other end
    is there a usual reason this may happen?
    I assume as the frost forms the coolant must be ok
    temperature is set to 2 degrees, i have checked, but cabinet wont go below 9 degrees now
    Apr 2008
    Southampton, England
    49
    1,045
    35
    Re: display chiller not getting cold enough
    Sounds (or should that be reads) sort of charge/restricted. Needs a chap with know how to confirm.
    Always worth blowing the condenser out with nitrogen / compressed air every so often as well.
    Cheers,
    Andy.
    Apr 2006
    1,645
    as said restriction or low charge, need to get a set of guages on it to know wich may be the case.
    Now in Redvers Sask.
