Results 1 to 8 of 8
    Nov 2008
    romania
    47
    45
    Dynamic air conditioning E 5 error .
    I have same error with 2 split sistems from Dynamic . Running fine half an hour and after that e5 error appears and the sistem stop . Starting again and running fine again . I did a check on the sensors but are fine . I don`t have any documentation on this split . I belive is maybe a problem with the indoor fan but i am not shure . Please if anyoane had the same problem tell me what should i check ? I must say i have different sistems same error ..12 k 18 kBtu .
    Oct 2007
    manchester
    5,639
    45
    Re: Dynamic air conditioning E 5 error .
    http://www.mediafire.com/view/m4oua3...ice_Manual.PDF
    see if this shinco manual is similar- a lot of chinese stuff gets rebadged
    E5 driver error- inverter circuit?
    Nov 2008
    romania
    47
    45
    No is an On-Off split sistem .
    May 2014
    Bulgaria
    32
    34
    If you provide photos of the units (better of the outdoors) I might be able to recognize the factory and give you a list of error codes.
    E5 in most of the units is lack of communication between the outdoor and the indoor. Most probably indoor PCB problem.
    Nov 2008
    romania
    47
    45
    2014-06-11 19.45.34.jpg It`s a simple on-off sistem no comunication between Indoor and outdoor .
    May 2014
    Bulgaria
    32
    34
    Correct, it is not exactly communication, it is a "dry contact" being sent from the IDU to ODU.
    If it doesn't work, then you might get the error.
    However this label is not familiar to me at all... Unfortunately I can't help you with this unit.
    Oct 2007
    manchester
    5,639
    45
    if all the sensors are giving the same resistance - indoor and outdoor, then check if your getting a signal to the outdoor- any condensate pumps with external fault contact, or some have a limit switch on the louvre motor- if they dont open fully then the unit just wont do anything
    Nov 2008
    romania
    47
    45
    No pump contact no floating switch . I just removed the electronic board and put a universal control board at 40 euro .....everything is ok now . **** China .
