Thread: second hand Eliwell ID961
12-06-2014, 10:01 PM #1
Hello,
I bought one. I have no experience with this controller yet.
The firmware - software seems to be different than usually written in manuals.
It has FAN menu, PA1 and PA2 protected area. Inside CNF, I can found H41, H42, PA2, REL, TAB menu points.
the REL == 23
Has anybody experienced such menu points, so this version has a custom code ?
If not, how can I access those menu points written in manual ?
The Machine Status Menu shows PB1 and PB2 probes, but this model has only one temperature input.
Any idea how to reset to factory settings ?
Thanks.
12-06-2014, 11:38 PM #2
Re: second hand Eliwell ID961
Ask Eliwell?
http://www.eliwell.it/WorkArea/Downl....aspx?id=18866
Page 14 and 18
http://www.eliwell.it/product.aspx?i...&LangType=2057
Rob
13-06-2014, 07:02 AM #3
I have the older version, with square front.
The tech support of Eliwell that was my last option.
Great hint!
20-06-2014, 06:58 AM #4
Give in the right pasword for PA2 to access program level 2 to see H41, H42,....If it's a 2nd hand , someone gave a password for PA (try 21, 22, -21 , -22) You can deprogram PB2 in some models (Evap Probe not present) in level 2
