Thread: Ciat dry-air cooler
11-06-2014, 08:43 AM #1
Ciat dry-air cooler
Hi I am having trouble running up a dry air ciat cooler.
water in let temp is 40c and set point is 30c but fans will not kick in.
its a brand new cooler.
There is power on the control board but the unit it self will not turn on.
any help.
cheers
model opera dln 9064-2 shi 745e 12a1
11-06-2014, 08:59 AM #2
11-06-2014, 10:48 AM #3
Re: Ciat dry-air cooler
Sorry, I don't know these units. But I had some trouble with a HP control a little while ago. It turned out that I'd been paying too much attention to explaining the system to the work experience kid & forgot to open the valve to the control.
It happens to us all.
So, I'd check that you have power to everything. And that the 3~ rotation is correct. Any fuses are ok. Overloads are ok. Any fan speed / HP controls are correctly set. All valves are in the correct position.
Then press every reset button that you can find.
If that doesn't work, have a cup of tea whilst perusing the manual & any wiring diagrams for clues.
Check Ciat's website and ring the local agent.
Good luck.
Finally, avoid Ciat equipment in the future! Lol
