Results 1 to 15 of 15
Thread: Screw compressor vibration
04-04-2006, 09:50 PM #1
I have 10 screw compressor York semihermetic in 4 air cooled chiller but a dont have a Service handbook for repair the compressor and i need the information about tolerants, torque and procedures of repair the compressor.
I want to know the vibration in this compressor because i need a reference.
my email: jpumarada@finlay.edu.cu
05-04-2006, 12:17 PM #2
Re: Screw compressor vibration
dear
you can get it from there site on internet
www.york.com
best wishes
afeef
05-04-2006, 12:34 PM #3
I'm looking in the site internet York but i don't see anything about screw compressor vibration neither procedure of repair of this compressor.
I need some help, because i have 1 compressor with problem of noise and i don't have a guide por inspection or repair.
Thans
05-04-2006, 01:02 PM #4
you can send email to york
or find any other company produce screw compressor , down load its manual from its site , cause all are mostly same fundementals , check these
www.trane.com
www.copland-corp.com
www.bitzeruk.com
www.daiken.co.uk
thanks
cheers
afeef
05-04-2006, 07:51 PM #5
due to political reasons h may have some difficulites with york usa.it's a strange set up
that aside havana is a great place to be ;-)) bring on the cuba libre !!
cheers
richard
05-04-2006, 09:14 PM #6
Give the types, we can use via here perhaps.
Afeef, I can't imagine that the figures (Torques, tolerances..) for one machine fits for another.
The basics how a screw works remains the same but not their figures.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
05-04-2006, 10:22 PM #7
Hello, Jpumarada try this page:
hope also others can find it usefull becuse it is some kind of York intranet with almost everything, spare parts, documentation...
https://www.refparts.york.com/
https://www.refparts.york.com/ALLParts/
06-04-2006, 06:22 PM #8
Peter_1
the model: DXS45LASA46/50, DXS36LASA46/50, DXS24LASB46/50.
This is the 3 model that i have, but DXS36LASA46/50 have a problem and we dont have de information about repair neather the number part of you are bearing.
This compressor have a noise and we think in the bearing but we dont have training in this type of compressor.
At this moment we take the messure of vibration in this compressor but we dont have the reference or the information for the correct level of vibration.
thank you
06-04-2006, 08:55 PM #9
Jpu
These compressors were originally listed by york as non service repairable and hence no tear down info was made available, this is probably still the case.
Al
07-04-2006, 12:51 PM #10
Jpu
Generally semi hermetic screws like the ones you have are very difficult to repair on site. Are there not any compressor re-manufacturers you could approach to have a look at the job for you? My company have used these types of companies before, they are pretty good in the UK. Hope this helps, good luck!
07-04-2006, 09:12 PM #11
hi jpumarada
What is the chiller model ? It should begin with YC..........? Maybe I could be of assistant.
11-04-2006, 07:30 PM #12
The chiller model:
YCAS0150EC46Y.
Stilo "G"
Thans
26-04-2006, 12:28 PM #13
I need information about:
1. The numbres of bearing that used and type the bearing in screw compressor model.
DXSA24
DXSA36
DXSA46
York
26-04-2006, 12:34 PM #14
Originally Posted by abdulazman
and the model of compressor is
DXSA36
DXSA46
I need information about this compressors, level of vibration, type of bearing that used and its numbres, information about sistem lubrication, because we dont have repair this type of compressor.
If you have any information about this I need you help.
Thank
http://www.york.com/products/esg/Ser...201.19-RP3.pdf
Here is a list of spare parts and some exploded view drawings of the compressor...
no tolerances or any other info
but it's a start
More info can be found here: http://www.york.com/products/esg/Ser...sp?prodid=ycas-Cheers-
Tycho
VSD on screw machines
By Mike Hopkins in forum New TechnologiesReplies: 14Last Post: 20-02-2011, 01:10 AM -
do u have any data on comparison of single screw and twin screw?
By vuputuri in forum Technical SpeculationsReplies: 5Last Post: 22-02-2008, 04:52 PM -
Mono or twin screw
By Nirmalya in forum Industrial CompressorsReplies: 43Last Post: 12-09-2006, 03:19 AM -
halls 2118 screw
By malvern in forum Industrial CompressorsReplies: 3Last Post: 14-03-2006, 09:15 PM -
screw compressor failure
By aygul in forum Trouble ShootingReplies: 23Last Post: 09-12-2004, 10:09 AM
