30-03-2006, 04:16 AM #1
Danfoss parellel scroll compressors
Who have used Danfoss parellel scroll compressors?
Any comments? per the catalogue,it's only needed to add a set of piping assembly,what you do is same as common single compressor. I ask for Sanyo, it looks more complicated.
Your comment is welcome
rgds
LC
30-03-2006, 07:22 AM #2
Re: Danfoss parellel scroll compressors
Danfoss, you mean Manneurop.
In order to have compressors in parallel you'll need three manifolds: one common manifold for discharge, one for suction, and an oil balancing pipe.
I don't know whether manneurope supplies those pipes, as their guys do not have the welding patents for lap joints brazing.
30-03-2006, 08:20 AM #3
Originally Posted by lc_shi
It's not an ordinary piping assembly. It consists of some discharge T's, an oil connection and on the suction side an oil separator/restrictor. This last one takes care of the 'dynamic oil balncing system'.
Take a look on the attachment. I hope it's clear, otherwhise contact your local danfoss office and ask for the leaflet 'Selection & Application guidelines' for Performer Scroll compressors. (If not available, I can PM it to you).
You can mount these compressors in tandem, trio or quatro. (2, 3 or 4 identical parallel). 3 and 4 : only for models SZ160 and 185.
Best regards.
Bruno
Hitachi scroll compressors
By tonydeith in forum CommercialReplies: 3Last Post: 21-01-2011, 01:48 PM -
Oil cooling circuit on Danfoss compressors?
By The MG Pony in forum FundamentalsReplies: 15Last Post: 16-10-2010, 12:33 PM -
crank case heaters in scroll compressors
By abbasi in forum FundamentalsReplies: 19Last Post: 03-08-2010, 03:04 AM -
Danfoss Compressors
By iceman007 in forum FundamentalsReplies: 0Last Post: 28-07-2006, 06:32 PM -
Scroll compressors
By bernard in forum Supermarket RefrigerationReplies: 12Last Post: 04-05-2005, 05:49 PM
