    Somerset
    69
    4,697
    Ammonia recovery rig
    Hi Guys.
    Checking the archives is inconclusive.
    Does anyone know of a commercially available (Ships to the UK considered) Ammonia recovery unit.
    I know about the 1 size unit Polar pumps do, just wondering if anyone come across any alternatives.
    Thanks Grizzly
    3,357
    Re: Ammonia recovery rig
    Grizzly,
    Here is one alternative!
    What do you want to do with it exactly, transfer gas only or liquid as well.
    Do you require a condenser etc.
    http://equipment.howecorp.com/viewit...ut-compressors
    Somerset
    69
    4,697
    Thanks my friend.
    I will check them out further.
    3,357
    Grizzly,
    Our company made our own on a frame , wheel etc like the simle one they show.
    Motor,Small Dorin compressor, oil separator, pressure switch, all off the shelf stuff.
    Works extremely well, only draw back on a larger pump out where transferring into a liquid receiver etc, pressure builds up so have to take it steady or run water over it.
    Small condenser would be better in some cases.
    Somerset
    69
    4,697
    Yes!
    We have similar that we have borrowed in the past from another region.
    However the lead times we are being given lately to respond, means that having our own is worth considering.
    Especially as the main tanker company we/most use have put up their rates, making them expensive when historically they were a viable option!
    Thanks for your input.
    Appreciated.
