27-05-2014, 10:50 AM #1
Daikin Reefer Reciprocating Compressor
I am having a problem with a Daikin reciprocating compressor model no.2HC5BLB-R (1978 MODEL)
It has 9 terminals on the compressor and all leads have been removed and was not even marked.
I need to run this compressor but unfortunately do not have the wiring diagram.
The compressor could run either on 200/220v ac or 400/450volts ac 50/60hz and is hooked up to a selector switch. Is that's the reason why it has 9 terminals. Does anyone know how to run this compressor on 400v/450volts and which out of the 9 terminals to use? Would really appreciate it
if someone has a complete wiring diagram for this compressor.
Thank you to all members of this forum.
01-06-2014, 08:32 AM #2
Re: Daikin Reefer Reciprocating Compressor
Hi Friend,
I did sen you its ... Pls check your email box. Pls check its.
See you
Reefermechanic.
02-06-2014, 09:52 PM #3
Thank you for the much needed information
Regards, Johnson
