20-05-2014, 02:51 PM #1
DX system using Deliver Tempreture Sensor control
Hi all,
I like to find out is it possible using DeliverTempreture sensor (before using return air control)
to control set point for DX system at Data server room.
I am using Unifliar model TD2242 /4 compressor 2 system air-cooled. set 25'C 50%rh
Thank
20-05-2014, 08:36 PM #2
Re: DX system using Deliver Tempreture Sensor control
It is better to use the return air sensor or even a room sensor.
If you use a supply (delivery) sensor the the temperature control will be poor due to the fast changes in supply temperature.Brian - Newton Abbot, Devon, UK
20-05-2014, 11:28 PM #3
Thank. I will explain to my end user
