    Feb 2009
    54
    143
    248 volt, open winding
    I have a 200v-230v 1 phase compressor that has the common winding open. Took power off, got back to it in 4 hours, same result, protector doesn't close. Checked voltage: 248 volts. Can this be the cause of the burn out?
    May 2012
    59
    1,528
    Re: 248 volt, open winding
    That is about 8 - 9% over??
    I know of sites that are rated 230v and we get 252v which is near to the 10% maximum.
    It is possible, but probably unlikely.
    Rob
    Feb 2009
    54
    143
    [QUOTE=Rob White;295950].
    Rob
    I will replace it tomorrow and will cut open the old one to see what happened.
