Results 1 to 12 of 12
Thread: R22 Toshiba VRF
14-05-2014, 10:13 PM #1
R22 Toshiba VRF
We have a customer with a 1995 R22 Tosh 3 pipe system with a non pumping inverter compressor. Replacing the circuit is not an option at present. so we are looking for either a compressor or an entire outdoor unit. Can anyone help?
Refrigerated Trailer Rental
14-05-2014, 10:25 PM #2
Re: R22 Toshiba VRF
I take it tosh can't provide 1
14-05-2014, 11:08 PM #3
Re: R22 Toshiba VRF
not on 22 they cant, disable it so it runs on 50% capacity
15-05-2014, 06:12 AM #4
15-05-2014, 10:04 AM #5
Re: R22 Toshiba VRF
T
Toshiba wont stock R22 spares no more, as previously can you not disable the faulty circuit and run on a lower capacity??
other than that ebay or find another system somewhere and pinch its compressor one night, i did that with a solenoid coil once and got caught tho so i wouldnt recommend this
15-05-2014, 02:22 PM #6
15-05-2014, 02:39 PM #7
15-05-2014, 04:18 PM #8
15-05-2014, 07:06 PM #9
Re: R22 Toshiba VRF
Can you get a R407C compressor instead?
16-05-2014, 04:56 PM #10
Re: R22 Toshiba VRF
The 10HP R407C and R22 Super multi compressors were externally dentical physically and internally electrically the same too.
Just the oil changed as far as I recall, that was all.
They never did an 8HP R407C system with inv\fix comps in one shell.
Mind you Tosh dropped R22 back in 98\99, maybe before that, so it was a fair while ago.
It's a long shot but try some of the old Tosh distributors see they have a comp lying about as a door stop or something.
Also Fridge motors in Reading and London Hermetic used to rebuild these compressors......just a thought
8HP version was comp type HV991CW-Y12 or p\n° 43141606
10HP version was comp type HV1201CW-Y12 or p\n° 43141705
Happy hunting
Have a good weekend
Loops
16-05-2014, 05:11 PM #11
18-05-2014, 05:10 PM #12
