Results 1 to 9 of 9
Thread: mitsubishi cpe52 compressor
14-05-2014, 01:13 AM #1
hi there: first time working on a mitubishi CPE52-3BWIIIM wich needs a new compressor,i have tried my local refrigeration supplier with no succes and the numbers for such compressor are not listed on their mitsibishi parts catalog, any idea where could i find this compressor or a replacement type model # will be greatly appreciated. compressor model RS2514ESH1 Im on Las Vegas NV US
14-05-2014, 04:53 AM #2
Re: mitsubishi cpe52 compressor
As Mitsubishi has discontinued their container line, compressors (and most other parts) are hard to come by. I have a customer with a couple CPE14-3BWIIIM2 and I've retrofitted copeland scroll compressors. The piping is a little different so it hangs out the front a bit but the units are now stationary so it doesn't much matter. I have a very patient wholesaler who was able to match up a suitable replacement. I can give you the copeland model but I'm sure the difference between the CPE14 and 52 so I'm not sure it will be the same. The 14 is a single compressor R-22 unit.
14-05-2014, 05:20 AM #3
CPE52 is a single compressor R-22 unit.
14-05-2014, 05:29 AM #4
I appreciate your share.
14-05-2014, 05:37 AM #5
could you send me that info? thanks beforehand
10-06-2014, 01:12 AM #6
10-06-2014, 04:30 PM #7
10-06-2014, 05:44 PM #8
Here are some pictures. This unit is going to be installed in a permanent location so we just need something that is going work and the neatness of the plumbing is not a major concern.
Model number of unit CPE52-3BAA
10-06-2014, 06:27 PM #9
