    Nov 2008
    nepal
    125
    Strange Problem on Sanyo ODU
    Recently, i found the strange problem on Sanyo ODU Units ( 20 HP and 18 HP ), compressors are not working properly but there is no error shown on remote.when we reset the ODU it works but after one day it will not work.refrigerant is also Ok.would some body guide me, what is the actual problem..? any solution for this problem..
    Nov 2008
    nepal
    125
    Re: Strange Problem on Sanyo ODU
    hi frens..any suggestions about this problem..?
    manchester
    5,639
    model number for outdoor please
    Nov 2008
    nepal
    125
    here is the model number of outdoor units:
    1.SPW-C1606DXH8
    2.SPW-C1806DXH8
    manchester
    5,639
    Nov 2008
    nepal
    125
    thank you install monkey..i will check it..
    manchester
    5,639
    common fault on sanyo's is theres 2 reversing valves- check both are operating ok, sometimes 1 will pass- check pipe temps on all 4 connections and compare against the other 4 way valve
