Thread: cooling water TDS
27-03-2006, 11:22 AM #1
cooling water TDS
dear all
this is my inquiry:
what is the maximum TDS (total dessolved solids) in cooling water of the cooling tower ?
what is the additives used in the cooling water ?
thanks
faithfully/ afeef
19-04-2009, 07:38 AM #2
Re: cooling water TDS
Maximum concentration should not exceed 300 ppm and to ensure that TDS does not increase you need to have Bleed off and add fresh water with less than 150 mm water as the make up.
Addition of chemicals to ensure the pH is slightly alkaline say pH of 7.5 to 7.8 would be better.
Cooling down the water in a 1000 liter container
By Joep Hogenhout in forum Technical DiscussionsReplies: 29Last Post: 21-04-2009, 01:27 AM -
water cooling coil
By Lc_shi in forum FundamentalsReplies: 11Last Post: 02-09-2006, 08:45 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Ransco 7102-1 Thermal Shock Chamber cooling water requirements
By billjduke in forum IndustrialReplies: 15Last Post: 24-07-2003, 08:20 PM
