Results 1 to 10 of 10
Thread: Danfoss DHP-A SP (ASHP)
10-05-2014, 06:36 PM #1
Anyone fitted one of these?
From the technical description it seems to be a Ground Source Heat Pump spoofing as an ASHP by using an air collector running glycol instead of the ground loop.
Client had one installed about 3-4 years ago and it's never worked properly, original installer from Cheltenham (could name and shame if pushed ) refuses to go back and fix and won't issue MCS certificate needed for DomRHI - so I presume system wasn't designed or installed to MCS standards, Danfoss been no help either!!
Rumours says Danfoss HP staff down to 3 in the UK - any truth?
Main issue is loads of High Pressure faults, though it is running into a buffer tank, so shouldn't really have those unless filters blocked (possibly/probably) or sensors up the creek.
We've got Wednesday morning booked in to see if we can fix or else rip it out and put a new split unit in that he can get DomRHI on. (So replacement won't cost him anything : ) )
10-05-2014, 08:55 PM #2
Re: Danfoss DHP-A SP (ASHP)
name and shame first! :-)
10-05-2014, 10:20 PM #3
Sha******* and Win*** ....
11-05-2014, 11:44 AM #4
Don't get shackled by them. I thought they were registered esp if they do council and housing association work around the area?
An ideal solution for Stroud District Council for
refurbishment of the older hot water and heating systems
in properties off the gas network would be:
| A solution using an affordable renewable energy source
| A reduction in carbon emissions
| Energy efficient system
| Affordable operating costs for the customer
| Controls that are easy to operate
| Low maintenance costs
come In and Just switch it On
Stroud District Council Refurbishment Programme
Jubilee Way Newtown Gloucester
| Safe and clean operation
| A fully functional central heating system
| Ample hot water.
| Installation cost that does not exceed that of oil systems
| Minimum disruption for tenants of occupied homes
| Improved EPC and SAP ratings
| Installer must be a MCS Accredited. (Microgeneration
Certification Scheme)
12-05-2014, 07:14 PM #5
Just because you've got the certificate doesn't mean you're any good...
We've fixed so many other 'certified' installers c*** u*s that we've lost count...
Good salesman never makes up for good design or good installation, unfortunately some customers can;t see through the smoke and mirrors...
16-05-2014, 11:03 PM #6
Danfoss made loads redundant a while back.....and now trying to hire again...tried poaching some people I know. If your ripping out why go for a split system, just stick with a monobloc....
17-05-2014, 06:10 PM #7
So so true, Weve followed many into properties where the instals have been shameful. However,
This is an old soapbox rant for me. It seems there are loads of Muppets going for all and sundry with quals for this and that , they acheive Competent person and MCS etc. but the instals can be so horrific.
I recently dobbed up an installer to the local building control, because he'd not installed pressure relief to a vessel, basically a time bomb. He copied this over into 3 dwellings.
His comment to the occupier was, " yeah they can blow up but only under very special circumstances...."
Frightening ....... but then that's the wet trade for you.Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
18-05-2014, 12:05 AM #8
Here's the video we show to custards as to why we can't work on it until we've fixed any unvented issues:
We all know that there are regulations around unvented cylinders, here's why: http://www.discovery.com/tv-shows/my...ter-heater.htm see what happens when the safety's are blocked off and it is just heated by the immersion!
And what it would do in your house: https://www.youtube.com/watch?v=9bU-I2ZiML0
Anyway back to origial post, installation is so badly done, it's actually going to pay the client for us to rip it all out and replace it with a properly installed split system that will be MCS and RHi compliant.
Why split? #1 reason: No need to glycol in heating system
18-05-2014, 09:04 AM #9
Brilliant Video Worcester.
Thanks for that!
18-05-2014, 07:35 PM #10
Not all need glycol, I don't get why the manufacturers haven't clocked on to frost protection yet. We don't specify it
