    yaodavid's Avatar
    yaodavid Guest
    Superseal sealant
    Hi Guys , have anybody use superseal to repair leak in an inverter cooling system and what is the criteria in order for it to work successfully . Thanks in advance .
    Oct 2001
    Nottingham UK
    5,668
    Re: Superseal sealant
    Can you give a heads up on Superseal? It's not something that's familiar.
    Oct 2007
    manchester
    5,639
    45
    ive tried it on a fujitsu 10kw split- it didnt work, 3 mth later ended up changing the lower condenser, i recommend glo stick's if your struggling to find a leak
    Quote Originally Posted by yaodavid View Post
    Nov 2008
    scunny!
    35
    302
    22
    Crack an egg in the high side
