Results 1 to 11 of 11
Thread: Gloves/PPE
02-05-2014, 04:00 PM #1
Gloves/PPE
What gloves do u guys use when handling gas? At college they said use latex gloves but I've found these to be pretty poo!
02-05-2014, 07:17 PM #2
Re: Gloves/PPE
Got some like these, expect they would act like a sponge with refrigerant though,
http://www.clasohlson.com/uk/Tegera-Work-Gloves/40-8445
Nitrile glove would be more robust than latex, I use them when working on oily/dirty stuff.Mostly found in Oxfordshire, UK :)
02-05-2014, 08:38 PM #3
Re: Gloves/PPE
i use gloves that are cotton with a bit of rubber around the fingers . i would call them general working gloves ?( any builder merchant ).
i use shut off valves on my lines and push whilst holding the hose and undoing the connector , quickly .
sometimes i say thats a bit cold and flick my glove off .
shock horror , sometimes the gloves are not around .
the more its done the better you get .
i think , yes respect what you are working with , but you are its master .
02-05-2014, 08:52 PM #4
Re: Gloves/PPE
I use those gloves the tight fit ones, usually with a latex over it. I do also have the "quick couplers" too but sometimes the unit is too close to the deck or other stuff in the way.
I've used some marigold type things with like fleece inside they seemed good but where massive n really awkward to use...
03-05-2014, 09:55 AM #5
Re: Gloves/PPE
angled qwik couplers will help keep your glove fetish secret!
04-05-2014, 11:15 PM #6
05-05-2014, 07:11 PM #7
Re: Gloves/PPE
I got the worst freeze burn of my career so far, the one time I wore gloves to take my gauges off a 410a system...
Tips:
check your hoses before you put them on. Any dirt or grit in the thread will make it harder to get off.
Reduce the system pressure at which point your hose is connected, anyway u can; drain high side hose into low side of system, pump down if possible before removing low side. Even just shutting down to equalise system will help. You should be doing this anyway to keep refrigerant loss to absolute minimum...
Get hoses with shut off valves or quick release. They are essential for working on air conditioners where shrader connections are only option.
Gloves, never found one suitable. The gloves that you can still actually move your fingers in don't prevent burns. The gloves that do stop burns are generally similar to boxing gloves and your more likely to loose the whole system charge and freeze burn the rest of your body or asphyxiate than successfully remove your hose.
05-05-2014, 09:03 PM #8
Re: Gloves/PPE
did a pot change on a panasonic urban 407c 25kw cond
had core removers fitted to hi/lo side- degassed,pressure tested and vacced- recharged- and the f**king core remover came away from the female part of the schraeder- always the hi side- shut it off and got the core back in- frost bite on me fingers- oil splatter up the outdoor pcb- spent over an hour with ear buds wiping the pcb and warming it under the hand drier in the bogs- luckily got away with the repair- sent the core removers back to javac- reply was over tightened- cheeky f****** ********! wouldnt mind but im built for speed and dont have mong strength!- still dont wear gloves- usually use qwik couplers- angled ones
05-05-2014, 09:33 PM #9
Re: Gloves/PPE
Got new Javac core tool, first time i used it it wouldn't seal on the fitting, had to use my 15 year old leaky one instead!
05-05-2014, 09:43 PM #10
Re: Gloves/PPE
had them ones from climate ctr c & p ones- the knurled thumbscrew isnt the best, but them javac ones when u screw them onto a schraeder stubb- you have to rotate the entire thing to get it off.
05-05-2014, 09:58 PM #11
Re: Gloves/PPE
The c&p one is my old one!
