Thread: Clarification
02-05-2014, 01:39 PM #1
Clarification
how do calculate the pressure drop in Vertical 20 meter duct and horizontal 30 meter duct
02-05-2014, 05:04 PM #2
Re: Clarification
There are various calculations you will need to do based on volumes, velocities, cross sectional areas and so on. If it is vertical or horizontal doesn't come in to it.
To aid with this complicated task there are various software packages available, some of which are free. Try searching the web for "ductulator", that used to be pretty good and easy to use as well as free but I don't know if it still is around
10-05-2014, 10:41 PM #3
Re: Clarification
If it's horizontal or vertical, that's not important. Speed, roughness of the duct, branches, elbows, flow,...that's important
