Results 1 to 10 of 10
    Apr 2009
    oldham
    36
    freezer low suction pressure
    Hi I have a copeland scroll condensing unit running a freezer coldroom, the unit gets down to -21c in no time and sight glass full with the occasional bubble . The only worry I have is the suction pressure is about 4-6psi which to me is too low. Liquid pressure is 200psi it has a new drier exp valve and orifice. So no blockages. Any info would be great
    Alex
    Oct 2001
    Nottingham UK
    5,668
    Re: freezer low suction pressure
    Without knowing the refrigerant and suction pipe temperature we won't be able to comment
    Apr 2009
    oldham
    36
    Sorry frank its on 404a I haven't taken a suction pipe temp
    Oct 2001
    Nottingham UK
    5,668
    I've been working on a CO2 tank cooler today on 404a with a suction pressure of 5psig and a discharge pressure of 200 psig when I got there
    Got the discharge pressure down to 105psig by deep cleaning the condenser then found that it was quite short of gas as the pipe temp was +7C.....didn't help that there was hardly any lagging on the pipe ...oh ...and discovered that it had an R22 TEV
    Can you post a full set of system readings?
    Oct 2013
    36
    147
    14
    You weren't at a nationwide bank in reading were you?
    Apr 2009
    oldham
    36
    Condensing unit about6 month old was on r22
    Feb 2009
    telford
    2,092
    33
    Check the txv,put a 404a valve on if it has not got one already and check bulb contact on outlet.
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by NewmanRef View Post
    Do they have a 12tonne CO2 tank as well?
    Apr 2009
    oldham
    36
    The valve is 404a and I checked the bulb which was sat on top of tue pipe so I moved it to the side which helped a little. Im gonna change the valve tomorrow and see if that helps. Cheers frank
    3,856
    Has it got the correct orifice in it? It would needed a bigger one than it had on R22.
