Results 1 to 10 of 10
25-04-2014, 01:58 PM #1
Need some help Daikin Ducted System
I could really use some help with a service manual for a Daikin ducted a/c. Outdoor unit model RY200KUY1, and indoor unit model number FDY80KAY1.
Problem is with the indoor part, fault code A6, which is from memory a fan motor lock, so not sure if the PCB is the problem or the fan itself yet, as haven't had too much time to look properly at it. It's a 2002 installation with a multipoint zoning system. I can't find a service manual for it anywhere, and I thought I would have one, but don't.
Thanks if anyone can help.....Makes a nice change from chillers !!!
a problem shared is a problem halved
25-04-2014, 05:02 PM #2
Re: Need some help Daikin Ducted System
The fault will stay in the memory until u clear it - press test to show the fault with controller off then hold on/off until it clears
25-04-2014, 07:42 PM #3
a6 fan locked-is the filter clean, does the fan rotate freely? maybe 1 of the tappings for the fan speed is dead, capacitor ok
Last edited by install monkey; 25-04-2014 at 08:24 PM. Reason: posted info on a6 louvre error-oops
27-04-2014, 11:43 AM #4
The filter is clean (first thing I checked). Access is not great so I have taken out the return air grille . I haven't been able to hand rotate the fan yet as I suppose I will have to strip half the unit out to get at it. The unit plate on the inside unit shows it having a three phase supply (even though I thought it would just take a phase off the condensing unit).
I thought about the capacitor as well but with no service manual it makes it harder. I did reset the fault but comes up immediately as soon as you turn on the controller.a problem shared is a problem halved
27-04-2014, 12:22 PM #5
http://file.thermotrade.ru/techno/Da...0manual_en.pdf
service manual
27-04-2014, 01:01 PM #6
Thanks. A little light bedtime reading. Something to look forward to fixing tomorrow in a 60 degree roof.
27-04-2014, 02:07 PM #7
28-04-2014, 01:21 AM #8
As it happens the belt isn't broken. The PCB looks OK as well, two flashing lights. The fan turns easily by hand, so that isn't seized. I couldn't stay there too long so didn't finish off, but it looked like the overload was tripped as it was sticking out quite noticeably, but as I have not turned off the power fully, I am not resetting it without checking the motor resistance, which should be all the same as it's a three phase fan motor. Once I've done that, then I'll check for the overload. Very strangely though, the breaker (when I left) was off and will not reset. the mechanism in them is supposed to snap it back to the on position when it's reset, and I noticed that there is no resistance to resetting the breaker, it just feels loose. You can hold it on, but it won't stay on, and this has been happening for a week or two I believe. Luckily I've got a spare one somewhere so will fit that later and check all the other things. Perhaps that will solve my problem, but if it doesn't then I'm down to the contactor/overload or the relay.
01-05-2014, 01:44 PM #9
01-05-2014, 06:01 PM #10
my first post should have said- is there any animals in it! haha
