Results 1 to 9 of 9
Thread: Nightmare :(
24-04-2014, 07:23 PM #1
Nightmare :(
Alright lads,
Had a suction valve to swap on a Mitsi vrv 2day it wouldn't heat up for love no money!
The bloody thing ended up shearing off as I'm tryna move it whilst heating it up with the oxy!
I reckon it's due to the wet rags on the brass valve behind it, reckon I'll need to braze it up without the rags?! Good idea?
24-04-2014, 07:24 PM #2
Re: Nightmare :(
Please don't point out I maybe should've cut the copper instead
Just to clarify I got a 1 3/8" to 7/8" reducer to join themLast edited by Anz; 24-04-2014 at 07:26 PM.
24-04-2014, 07:54 PM #3
Re: Nightmare :(
Brazing a valve without properly wet ragging it is never a good idea.
The solution lies in more power.
Bigger nozzle, perhaps a pepper pot type, is the way to go.
24-04-2014, 10:17 PM #4
Re: Nightmare :(
Changed a four way valve on one of those with only front access and it was a nightmare as that big brass manifold takes all the heat.I would wet rag everything. Two torches might be an idea. Get a pepper pot nossle or a big nossle like a 16. Even with rags the brass will absorbe a lot of heat. Was the old one leaking? Get the side cover off the unit to get better access for brazing. Good luck.
25-04-2014, 05:21 AM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Nightmare :(
25-04-2014, 06:44 AM #6
Re: Nightmare :(
Im gunna get the panel off 1st thing, I'm using a 16 tip, got a roxy kit too, I knew this was gunna be a swine!
26-06-2014, 02:12 PM #7
Re: Nightmare :(
My secret wepon is the smith quick braze torche with a big C style multijet tip, it is like a jewlers torch, great for such instences, and best off all got it from fley bay cheap, failing some investment in a simple torche as others said need to flash the heat into the joint faster befor it propigates to the valve, and all ways keep the valve quenched.
http://www.ebay.com/itm/SMITH-QUICKB...item4d1ef06637 here is a link to the first one I found if interested, I do highely recomend them, the hoses are crap but easy to replace, and it does make life real easy on such instences.Now in Redvers Sask.
26-06-2014, 06:00 PM #8
Re: Nightmare :(
I sorted it a while ago now, did it by using the van jack to get at it underneath n cutting a big hole in the case
26-06-2014, 10:03 PM #9
Re: Nightmare :(
oxy acetylene is best as its a confined heat- maybe use a turbo torch heat sheild to concentrate the heat - or as you say hacksaw the valve out and move the valve and possibly the flange forward- saves trying to unsweat it
