Thread: It is possible!
    Apr 2014
    Australia
    7
    It is possible!
    Is there a digital thermostat that can run two AC units simultaneously means at a time or is
    there another solution using one thermostat? Any views related this will be appreciated.
    Jan 2014
    Uk
    40
    91
    12
    Re: It is possible!
    Yeah, link the controller cable if they are the same manufacturer
    Feb 2007
    2,473
    45
    Re: It is possible!
    Are we talking electro mechanical thermostats or remote controllers?
    If the first then the solution is via relays, if the second then it will depend on the manufacturer.
