Thread: simple stuff
25-04-2014, 04:23 PM #1
simple stuff
Hi guys
Sorry for d basic q's
What should my pressures be on a small display chiller? Setpoint 2c gas 404.
Also another similar cabinet chill slight ice build up at start of evap coil could this be low in gas or just because d fridge is empty ?
25-04-2014, 10:08 PM #2
Re: simple stuff
the pressure should be 123456578...
Yepp, it could be low on charge... Could also be a myriad of other things.
To start with you need to check the running conditions of your system, discharge & suction pressures, Subcooling and Superheat, air on /air off evaporator & condenser and so on.
Then, and only then, can we make judgement on how the system is operating and why.
