Thread: Sabroe SAB 163 screws
06-11-2001, 08:21 PM #1
Anyone any experience of the SAB 163 Mk 3 (or whatever they are on now) machines on ammonia freezing plants?
We have Mk.1 machine that just runs and runs, but the Mk.2 machine we run beside it is a right pain in comparison.
I may look at replacing some recips by using a screw compressor and I do not want to ignore the "better the devil you know" saying by going to another make of machine and then have to build up operational experience from scratch.
Steve
20-01-2002, 06:16 PM #2
Try a quote for a Howden screw comp with a Sabroe controller
20-01-2002, 06:56 PM #3Originally posted by Nigel
I know Howden screws have been around for a long time but I have absolutley no experience or knowledge of them. I'll check them out anyway, but this is a long to medium term thing anyway so there is no hurry.
I just want to check out if we could replace a couple of Sabroe TSMC 108's that tackle the base load on a cold store, and then use the rest of the Sabroe recips as a method of taking up demand over the base load.
Steve
21-01-2002, 09:21 PM #4
Hi, Steve, I too have worked on MK1 sabs and found them to be a good compressor, with only the slide rings giving any problems if they arn't changed. With regards to the Howdens, they would be a lot stronger than the MK1 sab, with some I know of running still after 30 Years of little to no maintenance.
On new jobs we have looked at putting on the newer grasso screws, but it's hard to pass by a compressor as relyible as a Howden WRV for no increase in COP. A howden is a very simple compressor which can be overhauled with few tools and none of them specilized.
Regards. Andy.
23-03-2002, 12:53 AM #5
The SAB 163 Mk 3 is a much more reliable machine than the Mk2. They've put oil pumps back on the package & made some other improvements that eliminate many of the problems we had with the Mk2. Although the Howden is a reliable workhourse.
New Sabroe (Frick) Screws
By Andy in forum Industrial CompressorsReplies: 22Last Post: 21-05-2008, 04:28 PM -
Sabroe Recip
By Andy in forum Industrial CompressorsReplies: 36Last Post: 06-03-2008, 02:29 AM -
Sabroe oil filters..grumble, grumble, grumble...
By SteveDixey in forum Industrial CompressorsReplies: 3Last Post: 25-12-2005, 07:49 PM -
Repair of screws
By reggie in forum Industrial CompressorsReplies: 6Last Post: 04-08-2003, 05:26 PM
