    Apr 2014
    iraq
    43
    5
    Exclamation help me .. how I added oil to compressor for centrifugal chilled water
    Dear brothers .. help me how to add oil and which lubricate the parts of Eombrisr when you start chiller type (liters) compressor centrifuges(trane), because the index of oil are very few, and there are traces of loss oil on pump, and we have to address exuding, but I don't know from anywhere added oil, Attach your photo and special pump oil in trane chilled water .so I hope the people of experience help me to know the place for adding oil, as exists with pictures attached and the possibility Tachireha Aalsourh Thank you very much
    manchester
    5,639
    Re: help me .. how I added oil to compressor for centrifugal chilled water
    https://www.trane.com/Commercial/Upl...u02be4_205.pdf
    page 81 explains how to drain oil and re fill
    Oct 2013
    147
    14
    The 3/8" connection on the shut off valve under electrics box looks good. Do you have an oil pump? If so pump it in there. If not shut the compressor off, pull into a vacuum and suck it in there.
    Apr 2014
    iraq
    43
    5
    thanks dear Newmanref ....
    Is is possible to place marking Add oil .. inecate on photo plz
    Apr 2014
    iraq
    43
    5
    Quote Originally Posted by NewmanRef View Post
    how I can Open the oil charging valve on
    the bottom of the oil tank of
    the CVGF and operate the oil
    recovery and recharge unit oil
    pump to charge the oil into
    the tank.
    .... can u indecate that on photo plz
    Apr 2014
    iraq
    43
    5
    the tank.
    manchester
    5,639
    u might need to zoom on the pic
