Results 1 to 10 of 10
    Apr 2005
    Scotland
    11
    Carrier xarios 500
    Got a box running as a freezer on standby only, road compressor blanked off.
    When on defrost suction pressure is 2.6 bar but intermittently it rises to 8 bar and cuts out on hp2 switch
    Any ideas what could cause this ?
    Nov 2009
    Canada
    123
    15
    Re: Carrier xarios 500
    Quote Originally Posted by TransCool View Post
    is the condenser fan running and at the right speed?
    Aug 2011
    Canada
    160
    15
    What's your discharge pressure running?
    2.6 bar is the cpr setting. If the xarios 500 is the same as the NA 50x there is a bypass circuit around the CPR. When the discharge pressure rises above 27.5 bar HP4 will close, closing the bypass circuit and brings the CPR back into the system and should lower the discharge pressure as well as the suction.
    HP2 switch should cycle the fans on and open the condenser inlet solenoid at about 22 bar at 30 bar HP3 will trip and shut the unit down.
    Is the charge weight correct?
    Apr 2005
    Scotland
    11
    Condenser fan runs and cycles on pressure switch, new motor fitted 2 months ago .there is no by pass valve near CPR only a liquid injection valve
    On defrost when operating correctly head pressure sits around 11bar and suction 2.6 bar, when fault occurs head pressure rises to approx 21 bar and suction climbs quickly to 8 bar and above, unit trips pressure switch dropping pressure does this 2 or 3 times during defrost until it terminates defrost on temp and not time
    Fitted new standby compressor last week ,changed drier vacc end out overnight and new charge of gas weighed in,unit cools fine
    Feb 2009
    telford
    2,092
    33
    Why did you change compressor,maybe some **** gone into system,time to strip down upstream from compressor delivery
    Apr 2005
    Scotland
    11
    Quote Originally Posted by cadwaladr View Post
    Unit was tripping mains supply , dead short inside compressor, drained oil on old unit and oil was clean
    If condenser solenoid valve was leaking could gas come back through oil separator and into compressor via oil return line from separator ?
    May 2011
    Romania
    40
    84
    13
    Condenser valve leaking will not trip any switches only low heating capacity, hot gas valve leaking would be a problem, oil separators usually will fill up with dirt and not let oil back to compressor it's a must change when road comp fails, never heard of one letting hp back into suction... If used only on stby i would remove injection valve from circuit. Do you have 8 bar on suction after stopping or during operation?
    Apr 2005
    Scotland
    11
    Quote Originally Posted by sonkax View Post
    Suction pressure only rises to 8 bar and above on defrost builds up slowly then after about 6 bar rises quickly
    Going to attend today and fit solenoid valve repair kit , will keep you guys posted
    Thanks for all the help
    May 2011
    Romania
    40
    84
    13
    More likely it's the CPR. Put unit on heat and try changing the cpr settings, measure vap inlet and outlet press , see if messing with the cpr changes anything on suction side.
    Apr 2005
    Scotland
    11
    Fitted new CPR and repair kits to solenoid valves,Unit has been fine for a week now and all ok
