Thread: Td?
    Jun 2007
    saskatchewan
    56
    70
    Td?
    Which cooler would be dryer?A cooler running 10 temp differential or a cooler running 15 temp. differential?
    3,853
    Re: Td?
    The bigger the difference between the room temperature and the evaporating temperature the more moisture will be removed from the air.
