19-04-2014, 02:31 PM #1
Mitsubishi electric PAC SF83MA-E G A-M Converter
Ive been fitting these interface jobbys, to the outdoor units for others to link into a multi controller
(forgot controller model)
You get a sheet which gives you the fitting method... when you put outdoor model number to its category.
Straight forward enough, until I came to the last unit (PUHZ ZRP 50). Its not on the list.
I took the panels off the outdoor and it's impossible to get the converter pcb in there.
Do you guys know if there is an extra kit for this application ..... I was thinking, if the leads are long enough to allow me to put the converter pcb, into a weatherproof enclosure mounted on the front or back of the outdoor unit. Or maybe one of you guys have found another way?
19-04-2014, 02:37 PM #2
Re: Mitsubishi electric PAC SF83MA-E G A-M Converter
19-04-2014, 02:53 PM #3
Will have a look at that on Tuesday but Im sure there is no space on that outdoor unit to get it in there.... like I say that outdoor unit is not on the list.
19-04-2014, 03:01 PM #4
wrap it in bubble wrap and jam it in
