    Apr 2014
    Australia
    7
    Why do air conditioners blow out white smoke?
    I sure that something wrong when I see smoke from my AC. Any one knows that Why do air conditioners blow out white smoke?
    Oct 2008
    newbury
    1,444
    37
    Re: Why do air conditioners blow out white smoke?
    probably condensation after defrost...
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    High humidity and low fan speed. This happens often with Vehicle air-conditioners when the conditions outside are warm but wet and miserable. It's just fog or mist.
    Last edited by mikeref; 17-04-2014 at 10:08 AM. Reason: BTW, it only lasts for 15 seconds or so.
    Oct 2007
    manchester
    5,639
    45
    as mike says running a unit in cooling in low fan speed can create mist- its normal- also recommended to have louvres angled horizontal to prevent dew from forming
    Apr 2014
    Australia
    7
    Thanks all of you for to solve this problem.
    Apr 2014
    United States
    36
    2
    What kind of white smoke is coming out? Does it have smell? If smells none, probably its a condensation. Be careful also with refrigerant leaks since its very harmful when huffed inside the closed space.
    You can also seek professional HVAC advice
