    Oct 2008
    Vietnam
    Which valves for fcu"s & chilled water
    HI all
    looking for an overview of the type of valve choice for a two pipe chilled water system and FCU's. Does anyone have an over view of the, type of valve, its pros and cons and its location on the system?
    AND
    5,733
    Re: Which valves for fcu"s & chilled water
    You can use 2 types.
    2 Port = On/Off
    3 Port = Modulating
    Using a 2 port will give you poor indoor temperature control and a 3 port will give a closer temperature control.
    Have a read here https://customer.honeywell.com/resou.../95c-10830.pdf
