Thread: Carrier 1800 E Manuals
12-04-2014, 07:22 PM #1
Hi all
Does anyone have a manual (or training manual) for a carrier vector 1800 E please , or can point me in the right direction ?
I have one for the MT but its all different
12-04-2014, 10:50 PM #2
Re: Carrier 1800 E Manuals
What do you need to know mate?
13-04-2014, 03:35 AM #3
firstly buy a fire extinguisher,would have thought if you had a manual for a mt you could find your way around a single temp?
13-04-2014, 02:11 PM #4
Im trying to find out 2 things really
got a unit which isn't shutting down at temp and overrunning by 4.5 C before shutting off comp and bringing on heating in continuous mode. could this be a built in minimum run time ?
Also it seems to be doing this in start stop after a defrost , does it run in a different mode after a defrost , pulldown ?
13-04-2014, 04:47 PM #5
They swapping the battery firstly,is it a single temperature unit and is the water temp sensor reading correct.
13-04-2014, 05:45 PM #6
no water temp sensor , fully electric unit , no generator etc
16-04-2014, 08:27 PM #7
