Thread: Fujitsu Inverter
09-04-2014, 12:04 PM #1
Fujitsu Inverter
Hi All
I have a Fujitsu Inverter ASYG24LFCA. If I set the vent blades to a particular angle, after several hours it reverts back to its default position. This happens with the unit continuously turned on.
Does anyone know how I can change the default angle/position of the vent blades or get it to stay where I choose?
Mike
09-04-2014, 02:00 PM #2
Re: Fujitsu Inverter
Well I don't know about any Fujitsu specific way...
But the old engineer's trick is to disconnect the linkage to the motor(s) and use superglue to fix the vane in position.
09-04-2014, 07:42 PM #3
on most splits in cooling mode if you set the sirflow downwards it will revert to a horizontal position- usually after an hour on a mitsi unit- its to prevent condensation forming on the flap- which rarely happens, only way is either unplug the louvre motor off the indoor pcb or set it to swing
09-04-2014, 07:45 PM #4
As IM says...the only way to beat the computer is to unplug it
14-04-2014, 08:51 AM #5
Thanks guys, the plug is out
