Results 1 to 8 of 8
    Dec 2011
    Australia
    3
    McQuay Chiller oil diff problems
    Hi All,
    I have a Mcquay air cooled chiller with 2 x HSA3221QY11YB-S compressors.
    One compressor is faulting on high oil diff pressure fault.
    We have changed the oil filters on both compressors but this compressor still faults.
    Does anyone have an exploded drawing of this compressor and maybe theory of operation ect.
    Any technical advise regarding this chiller would be much appreciated.
    Kind Regards
    Craig dyer
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    49
    412
    23
    Re: McQuay Chiller oil diff problems
    hi,crig, welcome to re.what is your chiller model umber
    Dec 2011
    Australia
    3
    Hi Moideen,
    Model is ENP142.2 XE-ST
    Craig.
    moideen's Avatar
    Apr 2008
    u.a.e
    49
    412
    23
    have you check your oil pressure transducer,and provide the running parameters
    495
    21
    Hi your discharge pressure might be too high or as moideen says the transducer needs calibrating
    Dec 2011
    Australia
    3
    Thanks for you your quick answers )
    How do you calibrate the transducer, I do not have lap top access to the controller or pass codes for controller key pad programming.
    Any assistance would be greatly appreciated.
    Kind Regards
    Craig Dyer
    Aug 2014
    uk
    54
    5
    Any one have experience with excess oil consiquences on flloded oil screw compressor agr 212 mc quay
    Aug 2014
    uk
    54
    5
    Oil pump pressure -crank case pressure. Must be minimum of 01 bar. Called ney pressure
