28-03-2014, 10:57 AM #1
Danfoss 35BD not cooling more than 11.7 Celsius
I have a portable fridge Snomaster with Danfoss BD 35 compressor.
It is not cooling below 11.7. Celsius.
What can the probable cause be ?
Coenie
28-03-2014, 11:08 AM #2
Re: Danfoss 35BD not cooling more than 11.7 Celsius
Please read the temp as -Minus 11.7 celsius
28-03-2014, 11:52 PM #3
What temperature does it normally reach?
You say a fridge but expect freezer temperatures?Brian - Newton Abbot, Devon, UK
29-03-2014, 06:04 AM #4
29-03-2014, 11:22 PM #5
OK, understood.
Is the voltage to the compressor correct and is it running at the correct voltage?Brian - Newton Abbot, Devon, UK
02-04-2014, 10:46 AM #6
Brian
It is now working as it should.
I was impatient and should have waited a bit longer for the cooling to kick in properly.
But thanks for the advise.
Coenie
02-04-2014, 09:17 PM #7
OK, glad that there isn't a real problem.
