Results 1 to 10 of 10
    Feb 2014
    Pakistan
    4
    is it a creative idea or a dumb ?
    what will happen if we connect these copper pipes to a compressor.. will it provide a cool air in summer... ???
    Feb 2014
    Pakistan
    4
    Re: is it a creative idea or a dumb ?
    compressor and all other heat producing units is placed outside of room
    May 2012
    59
    1,528
    In what way would you connect it to the compressor?
    Are you talking about it being the evaporator?
    All you have made is a coil with a fan blowing air over it,
    it will work as an evaporator, but it won't provide much cooling.
    Where I come from we call that an Heath Robinson contraption.
    Use a proper AC evaporator and do it right.
    Rob
    Apr 2008
    Southampton, England
    49
    1,023
    I'd suggest a bigger drip tray if you intend to use the swing function...
    manchester
    5,639
    Oct 2008
    newbury
    1,444
    Looks like he's invented refrigeration!
    Apr 2006
    1,620
    Not sure if I aut to comment or run away fast!?
    Now in Redvers Sask.
    Oct 2013
    147
    14
    Slightly concerned about the PVC hose jubilee clipped to the copper! Are you intending to use these as refrigerant lines? Or you have a heat exchanger and pumping water to your indoor? Either way, this is completely insane!! Don't do it! Stop now! Swallow your pride and put all that back in the shed!
    May 2011
    Россия
    44
    Creative idea, but it is necessary to modify
    Eslirabotat will be on the cold water, then you can leave.
    If you will be working on *****, you have to add throttle, the compressor and condenser. Realize all line on the copper pipe.
    In both cases, to improve performance on the pipe must add finning and differently build the, to not interfere the flow of air, but maximally blew over.
    May 2011
    Россия
    44
    If you will work on the cold water, then you can leave.
    How do I edit my own posts?
