Thread: A/C Inverter
05-11-2001, 09:27 AM #1
A/C Inverter
I came across a Toshiba mini split a/c. recently. Model:RAS-225UAHV. Its a 110V unit using an inverter. All info. on this unit is in Japanese. The compressor nameplate says its 110v 3ph.
Could some tell me more about these INVERTER units.........thanks
05-11-2001, 11:22 PM #2
Hi Jai and welcome
I'm not a great lover of inverter units but the incoming 110vac single phase (I normally deal with 240v but...) is used to charge up some capacitors. The dc power from the capacitors is then fed through transistors (big ones) to create three phase ac voltage to feed the compressor motor.
I will try and find some more info for you and come back.Brian - Newton Abbot, Devon, UK
06-11-2001, 01:24 AM #3
Thanks for the info. Brian. All the electronic circuitry(capacitors, transistors,ic's, etc.) in this unit are damaged but the compressor is electrically O.K. I could bypass all the electronic circuitry but could I get the compressor to run on 110V or 220V ph1. I don't want to have to replace the compressor because of its odd electrical characteristics. I would appreciate any other info.
noise inverter compressor
By Airclima in forum Air ConditioningReplies: 1Last Post: 26-07-2007, 11:42 PM -
Inverter systems
By Latte in forum The Trail of TearsReplies: 23Last Post: 11-07-2007, 12:14 AM -
Can an inverter run off an indoor socket?
By stresshead in forum Air ConditioningReplies: 15Last Post: 31-08-2006, 09:56 PM -
Super inverter or 3 phase
By Cooldawg in forum Air ConditioningReplies: 7Last Post: 24-08-2006, 11:35 PM -
strange inverter problem
By rbartlett in forum Air ConditioningReplies: 11Last Post: 19-05-2006, 08:31 PM
